Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1060923-what-cpu-fan/#findComment-12538864
Yes, it's the top of the line model with heatpipes and copper bottom. But a bit noisy.
https://linustechtips.com/topic/1060923-what-cpu-fan/#findComment-12538919
comparable to the Hyper 212 evo which I use to overclock my i7, so I would say quite good overall. Far more stylish than the 212 with a less dated design but still cools well.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1060923-what-cpu-fan/#findComment-12538921
22 minutes ago, Plutosaurus said:
What's up with Cryorig H7 prices goddamn
I think they stopped being produced, nobody is stocking them anymore so the prices are set high. Not sure why, it's a good cooler.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1060923-what-cpu-fan/#findComment-12538928
I've got two of the quad lumi versions, and i paid like $59 each for them
over $100 for the non rgb versions, wow
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1060923-what-cpu-fan/#findComment-12538966
