This is my first time overclocking my cpu. I followed the instructions on the linked video to a T, except to the voltage of the cpu, as i didnt know what my cpu could handle. im averaging just over 4 ghz and peaking at 4.6. My highest cinebench score is 4714 if that helps any troubleshoot for me.
https://linustechtips.com/topic/1060712-i9-9900k-oc-problems/
This cpu has a turbo boost to 5 Ghz.
Leave it alone there with default settings in bios, it is more than enough.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1060712-i9-9900k-oc-problems/#findComment-12537349
The CPU Core Voltage will vary from one i9-9900K to another.
Yours might need 1.35V for 5.0 GHz to be stable.
This is usually why I typically recommend these guides to be...a guideline to get you started.
IMO, the best way to find out what YOUR CPU is capable of, is to do the manual labor yourself...like a real OG overclocker.
Start at the base clock 3.6 GHz, and gradually work your way up.
....just like tuning/modding a car, you don't go from stock 250 HP up to 700 HP at one go by following a build guide online...
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1060712-i9-9900k-oc-problems/#findComment-12537372
