Power Cables (GPU)
Go to solution Solved by Fasauceome,
It depends on the PSU but this is usually perfectly fine, I do this with my own Xp but I also have a nice PSU.
Hey guys,
Quick question:
From my PSU I have the cable running from the actual supply unit to my GPU. I Currently have a GTX 1070 and it only uses one 8pin cable. I am upgrading to  a Titan Xp and it uses an 8 + 6 pin connection.
My question is this: on that cable already running to my GPU there is a second set of 6+2pins dangling there, do I use this to connect the GPU or do I need to run a whole new cable.
I think I can just use that connector but I am not 100% sure so I thought I would ask.
Cheers!
https://linustechtips.com/topic/1060599-power-cables-gpu/
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1060599-power-cables-gpu/#findComment-12536142
OK I figured it would be fine, that's what it's designed for. I'll take a look in the PSU manual to see if there's anything mentioned about max wattage per socket.
Cheers.
https://linustechtips.com/topic/1060599-power-cables-gpu/#findComment-12536173
JayzTwoCents did some experimenting a while back and found overclocking was slightly more stable with 2 separate lines, but for regular people one line with the daisy chain is fine
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/1060599-power-cables-gpu/#findComment-12536220
8pin+6pin should be fine off the one cable.
If you're using a modular PSU with a high powered graphics card (2x8pin) it is usually recommended to use two separate cables.
Which PSU?
https://linustechtips.com/topic/1060599-power-cables-gpu/#findComment-12536973
