I'm looking to build out my work from home setup. The supplied computer is a 2018 macbook pro 15 inch (i7, 256 GB SSD, 32 GB ram, 555x), and I'm building out the rest of my setup:
4x dell u2718q (I need something vesa compatible)
2x double monitor arms
4x display port to display port
4x display port to USB C
Uniqey Q100, switch and cap swap
magic trackpad
Logitech MX ergo
Bluetooth mixer
Floor desk and chair
I will be using this setup with the screen open also using the native screen at 2880x1800.
So I have a few questions about this potential setup:
- Can I daisy chain the monitors together and still maintain 60hz on each monitor?
- If not, what are some recommendations for a hub or dock so I can input power and still have 60hz refresh rate on each monitor?
- Do I need any cooling for this setup? Ambient air in the next room over should be at 80 F, 5% RH
- How early of an early grave will I send my MBP to with this setup with/without cooling?
https://linustechtips.com/topic/1060432-building-out-4x4k-programming-rig/
magic trackpad
Logitech MX ergo
Bluetooth mixer
For a dock it’s expensive but good: https://www.amazon.com/Plugable-Thunderbolt-Charging-Compatible-DisplayPort/dp/B075M1XHCK
Get 2 of these https://www.amazon.com/Toshiba-43LF621U19-43-inch-Ultra-Smart/dp/B07D4F2P26 I know it’s a TV but massive screen space and you can window manage it
Get this mouse pircey but worth it https://www.amazon.com/Logitech-Wireless-Cross-Computer-Control-Graphite/dp/B071YZJ1G1
I’m starting to sound like a broken record player but this is awesome https://www.amazon.com/Das-Keyboard-Professional-Mechanical-DASK3MKPROSIL/dp/B008PFDUW2 or an ergomic keyboard https://www.amazon.com/Microsoft-Natural-Ergonomic-Keyboard-Business/dp/B004SUIM4E
Make sure to verify that everything plugs in or get subs c to usb 3.0 adapter
Get a good standing desk from your local brick and mortar store along with a chair, as it is too valuable (and big) to be shipped online
I think you can daisy chain though IDK
you computer won’t melt
Open the freaking window jk
There are adapters that support dual 4K@60Hz from one Thunderbolt 3 connection.
Displayport daisy chaining will not support 4x4K monitors. To daisy chain, monitors must support the feature.
To daisy chain monitors using Thunderbolt 3, the monitors would have to use Thunderbolt 3 connections.
Consider a cooling pad.
