So im planning a new build for later this year, and I already have the case I want to use, the H500. Here's my part list
 Ive been hearing that the h500 does not have good airflow, and that with a 2070 it'll become an oven. After the watercooling vid by LTT, I decided to use that cooler instead of an AIO. This kind of makes everything airflow based on a case that apparently does not have much of it. So, I need to know what to do. It would be nice to keep my current case, but if you think I have to switch cases, I need one that can match the aesthetic of this one. Or, should I get some nice case fans, would that work?
Thanks
https://linustechtips.com/topic/1060424-help-with-case-airflow/
AMD is releasing new CPU's and possibly GPU's in a few months, so your build may need tweaking.  Id' wait until you're within a month of buying it all before planning like that.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1060424-help-with-case-airflow/#findComment-12534554
Aesthetically similar cases with good airflow? NZXT H700, Fractal Define C/S/R6/S2, Corsair 270R/275R, 400C
Desktop benching:
https://linustechtips.com/topic/1060424-help-with-case-airflow/#findComment-12534564
If I may make a few suggestions....
If you're gonna get a Noctua cooler, get the better one that's actually cheaper
Also 8700K, $50 cheaper, performs about the same in games despite 2 less cores. Unless you're gonna be doing workstation that needs high core count, I can't see why to pay Intel $50 more. You also get 12 threads (hyper-threading) which they removed for the 9700K
Also Gigabyte Aorus board, these Aorus boards are probably the best bang-for-buck Z390 boards now
Get a better PSU, with the budget freed up from those 2 items I got you a fully modular MWE Gold, 650W too.
PCPartPicker Part List
CPU: Intel - Core i7-8700K 3.7 GHz 6-Core Processor  ($359.99 @ Walmart)
CPU Cooler: Noctua - NH-D15 82.5 CFM CPU Cooler  ($89.85 @ OutletPC)
Motherboard: Gigabyte - Z390 AORUS ELITE ATX LGA1151 Motherboard  ($159.99 @ Amazon)
Memory: G.Skill - Trident Z RGB 16 GB (2 x 8 GB) DDR4-3200 Memory  ($119.99 @ Newegg Business)
Storage: Samsung - 860 Evo 500 GB 2.5" Solid State Drive  ($79.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  ($44.89 @ OutletPC)
Video Card: Gigabyte - GeForce RTX 2070 8 GB WINDFORCE Video Card  ($478.99 @ SuperBiiz)
Case: NZXT - H500 (White) ATX Mid Tower Case  ($69.99 @ Amazon)
Power Supply: Cooler Master - MWE Gold 750 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($77.99 @ Amazon)
Total: $1481.67
Generated by PCPartPicker 2019-05-02 23:24 EDT-0400
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
https://linustechtips.com/topic/1060424-help-with-case-airflow/#findComment-12534589
I agree with bigrom quite a bit. Get a 8700k. Also you really dont need 3200MHz ram, 2666 is enough imo. Then with saving from both of those get a better psu. Also although you can easily get away with that motherboard I would recommend going to at least the $200 level. I personally like asus but the aurus boards do seem to quite the steal plus its always nice matching stuff.
I would take linus's video with a grain of salt, blender stresses the cpu way more than gaming will and if you have headphones on you are not going to be hearing fans with a noctua or aio.
Main Computer: Intel 9900k, Asus Maximus XI Formula, Corsair Vengeance RGB Pro 4x16GB 3000MHZ C15, EVGA GTX1070 Hybrid, Corsair HX850i, Lian Li PC-O11 Dynamic, 26TB
2: Xeon 2695 V3, Asus x99-A II, Corsair Vengeance Pro 4x8GB 2666 C15, Corsair RX750
3: Dell R510 8-Bay, dual x5675, 16GB ECC, 8x600GB 15k SAS
https://linustechtips.com/topic/1060424-help-with-case-airflow/#findComment-12534960
Thanks
Other than the psu this is a pretty good build. If you are concerned about improving airflow you could add a second 120mm front intake fan. There are cases with better airflow, but I don't think one is really needed and finding a decent one in white would be difficult.
The cpu cooler is quite good and has the advantage of not interfering with the glitzy Trident Z RGB memory.
If budget allows you might consider SeaSonic FOCUS Plus 550 Gold or Corsair RM550x (2018) in place of the CX550M.
https://linustechtips.com/topic/1060424-help-with-case-airflow/#findComment-12535727
Ok, i'll go for the RM550 instead. Budget does have some wiggle room, since ill just be taking my storage from my current build, and I already have the case.
I wanted to get the 9700K for the high overclocking, and I plan to also do some vid editing for a friend of mine. Also, would more cores be better than more threads for more applications open?
https://linustechtips.com/topic/1060424-help-with-case-airflow/#findComment-12535886
Thanks
Why not grab a Dark Rock Pro 4 for a few bucks savings? (And hey, it's not the ugly ass brown!)
https://de.pcpartpicker.com/product/F3gzK8/be-quiet-dark-rock-pro-4-505-cfm-cpu-cooler-bk022
As for the airflow, the case has sufficient grilling for intake. It supports either 2x120mm or 2x140mm fans for intake, and supplies 2x120mm exhausts... So really it's got decent airflow, you just need to grab a couple of intake fans.
2x140mm intakes plus a horizontal CPU cooler like that, a blower GPU, and dual exhaust routes is PLENTY of airflow. Not to mention in that setup, it's routing directly past your CPU to exit.
https://linustechtips.com/topic/1060424-help-with-case-airflow/#findComment-12536565
...Also, would more cores be better than more threads for more applications open?
Applications do not necessarily use cpu resources when open. Most applications spend significantly more time blocked waiting for an i/o completion or idling than actually using the cpu.
https://linustechtips.com/topic/1060424-help-with-case-airflow/#findComment-12536657
Sure, seems about the same performance wise, also not brown. Have you seen their really tacky chromax fans lol, they prob perform really well but they just still look so crappy rip. The only thing im kinda worried about is my cooler canoodling with my ram.
https://linustechtips.com/topic/1060424-help-with-case-airflow/#findComment-12536937
I can't make any guarantees, but here is a reference photo... Looks like it sits right on top. Just don't buy sticks with a super tall spreader.
In the tier lists, the Dark Rock Pro 4 comes highly recommended. I would totally get one :P
https://linustechtips.com/topic/1060424-help-with-case-airflow/#findComment-12536948
Lmao that almost exactly matches the parts im gonna buy. Thx
https://linustechtips.com/topic/1060424-help-with-case-airflow/#findComment-12536956
