Upgraded from an FX-8350 and gtx1060 back in December. Here's the new build:
-Ryzen 5 2600 @4.0ghz
-16gb Corsair Vengeance RGB @3200mhz
-Gigabyte AB350M-DS3H motherboard
-GTX980ti hybrid
-240gb ssd & 1tb hard drive
-500w EVGA power supply
-All in a Fractal Design Meshify C Mini case
-The monitor is a Lenovo Y27g
What do you guys think?
https://linustechtips.com/topic/1059911-my-ryzen-build/
I absolutely love the black and purple theme you have got going on there! I personally rock a black/white and purple theme myself. :)
The two AIO loops crossing each other looks nice, I love how the tubes flow pretty much in parallel.
Awesome work. :)
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/1059911-my-ryzen-build/#findComment-12529400
Love it!  You got custom PSU sleeves, makes it even more slick.
Only thing I would attempt to change is get the Cool Master logo on the CPU pump upside down..Does it interfere with the Ram slots or something?
I7 9700k- MSI Z390 Gaming Edge AC - Be Quiet Dark Pro 4 - Corsair Vengeance LPX 3200 2X8GB - EVGA RTX 2080 TI Black Edition - WD BLACK NVMe M.2 500GB -  EVGA Supernova 650 P2, 80+ Platinum -Nzxt H500 - Display Dell S2721DGF 27" - Keyboard- Razer Huntsman Mini 60%  - Mouse- Logitech G203  - Headset  Astro A50 2019 Edition - Speakers - Logitech Z623
https://linustechtips.com/topic/1059911-my-ryzen-build/#findComment-12529685
No, I just didn't like how the hoses were routed with the pump the other way
https://linustechtips.com/topic/1059911-my-ryzen-build/#findComment-12529753
Nice one.. you can always go back if the powerdraw of the 980 is not needed, i change cards once in a while, especially when i used it a lot...
With xmp on 3000 my 2600 averages on 3,90 all cores during bench btw ^^ No need for special settings in that way amd's precision boost apperently works
https://linustechtips.com/topic/1059911-my-ryzen-build/#findComment-12530668
