Hi guys, I’m in desperate need of help, I’ve just upgraded my pc to a Aorus pro Z390 mobo and i9-9900k cpu with an H150i cooler. I’ve put it all together and i can’t get nothing  to show on my screen the Bios doesn’t load iv’e taken  the GPU memory and CPU out  and the pc is showing nothing still  all  fans spin the rgb lightning is coming on but nothing on screen. I really need suggestions cos at this point I’m lost
 CPU: i9 9900k @5.1ghz | GPU: Asus Strix 2080Ti OC | Cpu Cooler : Corsair H150i (360mm) | Motherboard: Gigabyte Aorus Pro Z390F  | RAM: G.Skill Trident Z RGB 32gb 3600Mhz CL16  | Boot / OS SSD : Samsung 970 Evo 500gb M.2 / Samsung 850 Evo 500Gb SSD / 1TB SEAGATE HDD Case: Corsair Obsidian 500d SE RGB | PSU: Evga SuperNova Platinum 8
https://linustechtips.com/topic/1058695-please-help-bios-not-loading/
the CPU has an integrated GPU on the chip, if you plug into the motherboard and not the GPU, do you get any output?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
No nothing still
No nothing still
1 minute ago, Surreals said:
No nothing still
Try individual RAM sticks in each slot and see if you get a post.
Community Standards
"Beast Mode"
Did that also and no post still
Looking at the product specs, your board has a dual bios build. You should have a switch on your board you can change to activate the back up BIOS and see if you get any post there.
Community Standards
"Beast Mode"
I’m looking for this switch but can’t find it  what am I looking for? Cheers
Consult your motherboard manual for its location.
Community Standards
"Beast Mode"
Looks more like a chip than a button, sorry I’m a bit of noob on PCs
Yes there is a 2nd chip, but there should be a dip somewhere to switch over to it. I believe that is how it is failed over. I could be wrong, but pretty sure thats how its usually done.
Community Standards
"Beast Mode"
I just looked at the manual on line.  You have to short out two pins to clear the BIOS (CLR_CMOS jumper) and reset it to factory settings.  This is on page 24 of the manual I looked at.  If that doesn't work you might just have received a DOA MoBo.
Workstation PC Specs: CPU - i7 8700K; MoBo - ASUS TUF Z390; RAM - 32GB Crucial; GPU - Gigabyte RTX 1660 Super; PSU - SeaSonic Focus GX 650; Storage - 500GB Samsung EVO, 3x2TB WD HDD;  Case - Fractal Designs R6; OS - Win10
