1 - No I don't think you could get it
2- I doubt it will work on normal pcbs since it doesn't use the normal pin layouts as it is a contactless optical switch. 156644346_RazerOpto-MechanicalSwitch(2018)Render(5).jpg.816d9eb788982a4d70a9d0964cc874e5.jpg
3- A switch that would feel and sound similar would be box whites
4- "btw i am gonna change the springs" why? What springs do you have, SPiRT springs?
https://linustechtips.com/topic/1058645-some-keyswitch-help/#findComment-12518879
