I know cable management sux.
anyway GPU is gigabyte windforce oc rtx2080 with nzxt G12 and corsair H105.( i use evga precision too +100 clock,power target 109, temp target 88c) pulling air in from top with 2x 120mm ll fans.
CPU I79700K 4.9GHZ with corsair h150i pro, pulling air in from front with 3x 120mm ml fans > 3x 120mm ll fans as the picture.
when gpu 99% use it gets max 74-77c
when cpu 99% use gets 60-65c
also 1x 120mm ll fan at the back pulling air out
is these results too bad ? i used thermal grizzly for thermal paste to cpu and gpu.
max rpm speed i use 1100-1300rpm, i dont want to go further. also my case is small as you see.
please give suggestions.
https://linustechtips.com/topic/1058540-temps-high-or-normal/
-snip-
Have the fans for the GPU rad pulling air out of the case imo. Also most air coolers do very well compared to an AIO on a GPU.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/1058540-temps-high-or-normal/#findComment-12516887
the stock fans was hitting 88c on 100% fan speed it was arround 3000rpm, now 1100--1300 rpm 77, for me its excellent but i want to hit more than 1950-1980mhz on gpu, is there something else for allowing that ? (other than expensive custom watercooling stuff)
also if i turn the fans arround the temp doesnt change other that coming massive heat from top of the case, also for settings the fans on the upper side i cant do that, if you look at the right side radiator hits the other radiator it doesnt fit :/
https://linustechtips.com/topic/1058540-temps-high-or-normal/#findComment-12516965
Your gpu should be running much cooler. Have you tried reseating the cooler? It's pretty easy to get an uneven mount which can result in much higher temps. What rpm are you running the fans at?
https://linustechtips.com/topic/1058540-temps-high-or-normal/#findComment-12517204
i cant reaseat it no space, 1100-1300 rpm
https://linustechtips.com/topic/1058540-temps-high-or-normal/#findComment-12518657
What do you mean by no space? If you installed the gpu cooler in the first place, you can install it again.
https://linustechtips.com/topic/1058540-temps-high-or-normal/#findComment-12518994
A general rule of thumb is that you do not want to dump heat into your case, so why not having the fans of your top radiator blowing that heat out?
The less heat you dump and circulate inside your case, the better for your components like RAM, VRM, chipsets and so on and keeping things cooler in general.
Especially as the GPU does not gets any higher temps drawing out pre-heated air from your CPU-cooler in the front.
The whole reason to get watercooling / AIO is move the heat from the inside of your case to the outside, as aircoolers normally dumps the heat inside the case, but with WC/AIO you can place the radiator on the edge of your case, directing all the heat outside directly.
https://linustechtips.com/topic/1058540-temps-high-or-normal/#findComment-12521258
