55 minutes ago, iliyato said:
1.is it good thing/bad thing?
That depends. If you're trying to push the CPU to its limits, it's a bad thing in the sense that it's keeping the CPU from being pushed harder. Otherwise it doesn't matter.
Quote
2.how do i stop it?
You have to adjust the power limit. I haven't messed with this tool enough but I'm sure raising the "Turbo Boost Power Max" and "Turbo Boost Short Power Max" values would allow you to push it further.
Every KBL-R / WHL-U laptops will have power throttling under multi core load. This is due to high clock speed and high core count while TDP / PL1 is only 15W which is insufficient. Undervolting will only increase clock speed (not to max potential in most cases) and drop a bit of CPU temp
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
well it did dropped the temp quite good' the laptop less randomly ramps up the fan ( i also replaced the stock thermal compound with arctic cooling MX 4).Is it  a good thing is undervolting the integraded HD graphics? will i benefit some thing?
3 hours ago, iliyato said:
MX 4
Bad for laptops
Not much benefit from my observation
Desktop specs:
1 hour ago, iliyato said:
still better than stock thermal paste
can dry out quickly fyi
Desktop specs:
