I've had Linux Mint installed for about a month now, with no major issues, save for one.
I'll have good internet connection, but it will come in and out. For example I can try downloading any file, and it'll work for a few seconds and then just stop. I can disconnect from the wifi I'm on and reconnect or just shut off the wifi and turn it back on and it'll work again for a few seconds and then do the same thing.
I hadn't posted anything about this because orginally I was going to try running an ethernet cable from upstairs into my room to see if that would fix the problem but that has been delayed so I'm turning to you all for help..
ALSO if anyone can help please explain in easy to follow terms, as I'm still not very familiar with the technological side of linux yet icon_wink.gif
Thanks in advance, I've been looking around everywhere and this is the third forum I've found myself posting on, hopefully I can find a home here :)
Also was doing some digging and found other people with similarish problems and their adapters were showing up when they run lsusb in terminal. I don't know if this is relevant to my problem but the adapter does show up and I can't find the firmware file for ar9170 or ar9101
[color=#2E8B57][font=Monaco][size=12px]Bus 001 Device 008: ID 0846:9001 NetGear, Inc. WN111(v2) RangeMax Next Wireless [Atheros AR9170+AR9101][/size][/font][/color]
[color=#2E8B57][font=Monaco][size=12px]Bus 001 Device 005: ID 0409:005a NEC Corp. HighSpeed Hub[/size][/font][/color]
[color=#2E8B57][font=Monaco][size=12px]Bus 001 Device 004: ID 0bda:0111 Realtek Semiconductor Corp. Card Reader[/size][/font][/color]
[color=#2E8B57][font=Monaco][size=12px]Bus 002 Device 002: ID 1532:002e Razer USA, Ltd [/size][/font][/color]
[color=#2E8B57][font=Monaco][size=12px]Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub[/size][/font][/color]
[color=#2E8B57][font=Monaco][size=12px]Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub[/size][/font][/color]
[color=#2E8B57][font=Monaco][size=12px]Bus 001 Device 006: ID 1038:0510 Ideazon, Inc.[/size][/font][/color]
https://linustechtips.com/topic/10583-linux-mint-14-wifi-problems/
I think the issue is that it's a USB Wireless adapter, using the ndiswrapper package u should be able to get Mint to use the Windows driver. U'll need the orginal driver cd tho, unless u download them. Here's a link to some instructions on the Ubuntu site that should work fine, i'd run a search on the repositories for a Netgear WN111 driver first tho. https://help.ubuntu.com/community/WifiDocs/Driver/Ndiswrapper
"Sex is one of the nine reasons for reincarnation. The other eight are unimportant."
        - George Burns
  • 1 month later...
i have a usb wireless adaptor sometimes it will slow down. i think it just overheats sometime. maybe have two and swap them if one gets slow. then the other one would be ready by the time it cools down to swap. mine doesnt slow down often or for very long.
Cpu: Intel i5- 4570 | Ram: Crucial DDR3 8GB | Video Card: Evega GTX 660 Ti 2GB Super Clocked
Monitor: Philips 24" | Keyboard: CM Storm Quickfire TK | Mouse: Logitech G700s |
Steam
