Hi guys it’s my first post here so please excuse my ignorance.I was strongly thinking about getting a laptop for school as I’m going to move away in a few months and likely won’t be able to take my beloved desktop with me , I am leaning towards apple, but I’d rather not buy into the Mac ecosystem without trying the OS out for a few days , I have a ryzen 2nd gen system with an nvidia gpu so I doubt whether I’ll be able to run it on baremetal , I was thinking of running it in VMware/virtual box as they usually were very handy for other virtualization projects but I’m not sure if since I have only 1 gpu I’ll be able to use a hardware renderer in my vm and that’s why I would like to ask if macOS Mojave’s would be usable with a software renderer as I simply wanted a test drive of the OS for a couple of days to see if apple is the way to go for me.
https://linustechtips.com/topic/1058049-vmwarevirtual-box-virtualization-and-macos/
Use this guide, worked on bare metal for my system (in signature)
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
Thanks for the guide , I did consider doing it but I’m not sure if Nvidia has proper drivers for Mojave and as far as I know running high Sierra would involve
a parched kernel / some workarounds and whilst sure it’s doable I’m just not sure if I’d like to completely wipe my drive and install macOS as I believe macs use a different type of partition map.Still I’ll have a look and thanks for the quick response
To answer your questions...
Yes macOS can run on VMWare but it requires a patch, I can't link it here but Google VMWare Unlocker. Is it worth it? No. It runs slow as all hell and VMWare Tools doesn't work so you have only VGA video.
You can run it on bare metal, you're correct that you'll have to run High Sierra but that's not a big deal (it actually has some advantages) and as for custom kernels, Google AMD OSX and you'll find a nice site with a pre built image ready to go including* full instructions on how to get running.
Yes, Apples use HFS/APFS, I simply use a second drive and install to that. Clover will find your Windows install and add it to the boot menu. Heck I've even done triple boot with Windows, Linux & macOS using Clover before.
*turns out they pulled the pre compiled images from the site, I guess Apple were not happy with them distributing modified macOS.
Main Rig:-
Server:-
