Hey guys,
I am looking forward to build my first pc. I would like to hear your opinion on my parts. The PC will be used mainly for gaming and Office work maybe some light photo and Video edditing. And I will try and overclock all components. And maybe I should say that some parts are there mostly for looks. I wanted the pc to look very good. My budget is roughly 1000€ (I am from Germany) and that's what I am looking at:
  • CPU: Ryzen 5 2600
  • Mobo: msi b450 gaming pro carbon (are there any other b450 mobos with integrated wifi, cause I need wifi? Or is there really just this one?)
  • CPU cooling: enermax aquafusion 240 (I know that I don't need a 240 liq cooling for the CPU but it looks so good)
  • RAM: 16gb of trident z rgb or corsair vengeance rgb pro (what speed would give me the most power for the money? Should I go 3000 or higher? Or is 2666 enough?)
  • Some ssd (whatever I could get for a good price, and I have some hard drives which I can reuse)
  • GPU: Asus Arez vega 56 (It is under 300€ here)
  • PSU: be quiet pure Power 11 600w or corsair vengeance 650m (is the corsair one good? I am not sure on this. And is 600w enough or to much for this system? Do u have some other psu's u can recommend?)
  • Case: Asus tuf gt501
I hope the parts fit together. Thx for ur help!
https://linustechtips.com/topic/1057839-first-build/
https://pcpartpicker.com/products/motherboard/#c=133&e=63,31,15,30,14,6,8, a list of B450 motherboards with wifi. Ofc you could also get a PCIE wifi adapter.
I personally would get 3000Mhz, but 2666 should be enogh if you don't like paying the bit extra.
Those all should work together. I don't know if you've used it, but for future reference pcpartpicker will automatically do compatibility checks.
Specs: CPU: AMD Ryzen R7 3700X @4.4Ghz, GPU: Gigabyte RX 5700 XT, RAM: 32 GB (2x 8GB Trident Z Royal + 2x 8GB TForce Vulkan Z) @3000Mhz, Motherboard: ASRock B550m Steel Legend, Storage: 1x WD Black 1Tb NVMe (boot) + 1x Samsung 860 QVO 1Tb SSD (storage), Case: Thermaltake Core V21, Cooler: Noctua NH-D15
https://linustechtips.com/topic/1057839-first-build/#findComment-12510084
I wouldn't do an AM4 board from MSI to many issues.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1057839-first-build/#findComment-12510090
Just now, Pascale05 said:
Yeah I used pcpartpicker, but I just wasn't sure with the psu. And before I spend that much money I wanted to do a double check.
Thanks for the new list Luke, I will consider some of these parts.
If you're not planning on OCing the card outside its turbo settings, you can forego the cooler and save some money.  The stock cooler is great for even a slight OC.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1057839-first-build/#findComment-12510104
2666 and oc is a option on a budget, but with this i would say 3000 directly
3 minutes ago, Happycowdance said:
you know there's a german pcpp?
i mean, i can help great on that part... 600w is enough, but i noticed the little price difference between the 600 and 700. quality is most important here
vengeance is decent, the bronze is on the level of the cx 2017, and the silver somewhere between the cx 2017 and txm
https://linustechtips.com/topic/1057839-first-build/#findComment-12510106
tho the 2600 cooler is worse than the 1600 unfortunately
but even a air cooler is cheaper than that aio
https://linustechtips.com/topic/1057839-first-build/#findComment-12510110
1 hour ago, lee32uk said:
Such as ?
The X470 Pro Carbon has tons of issues some of which I've personally dealt with while fixing a friends computer. It didn't even work with the 2700x for some people until MSI fixed it, and a majority of the MSI AM4 boards issues have been fairly serious, Incompatibility issues even though it's the right chipset, DOA boards, firmware updates causing issues with the CPU's, it's mostly fixed through bios updates but  AM4 has been one of the worst launches for MSI boards, it's all over a lot of the forums. I love MSI and have used tons of their boards in the past but after having to deal with the issues I have with the X470 Pro Carbon and learning about the issues the entire line of AM4 MSI boards have had I just cant recommend them for this particular chipset. The only one out of the MSI AM4 line that apparently hasn't had any issues is the Tomahawk.
https://linustechtips.com/topic/1057839-first-build/#findComment-12510795
You can find issues with any AM4 board though if you google it. I had issues with a Gigabyte board that refused to boot with Corsair Ram or would give me a black screen etc. I had to swap it out for some Kingston and it was ok after that. One of the downsides MSI had was the lack of offset voltage but I believe they have sorted that out with bios updates.
https://linustechtips.com/topic/1057839-first-build/#findComment-12510981
Yeah a majority of the issues have been sorted out with bios updates, which is great. I mean I'm sure a lot of them are ok but the Pro Carbon series is a crap shoot and MSI's RMA skills are meh.
https://linustechtips.com/topic/1057839-first-build/#findComment-12511038
The B450/X470 Gaming Pro Carbon both have solid VRM's though. Look at Asus lower end boards as a comparison i.e B450 Prime Plus and the B450 TUF. They are a joke for the price they are asking. You have to look at the X470 Prime upwards for a decent Asus offering. At least with MSI they have some good value lower end boards. As for RMA I haven't used MSI myself so can't speak for that, but I will say that Asus are no better in that regard at least in the UK.
https://linustechtips.com/topic/1057839-first-build/#findComment-12511102
Yeah the VRM's are solid but the issues a majority of people are having with the Pro Carbon series have nothing to do with the VRM's.
https://linustechtips.com/topic/1057839-first-build/#findComment-12511113
