Help - Computer Noise
Go to solution Solved by Fasauceome,
13 minutes ago, SometimesStuff said:
Not to hand, I could probably get a cheap Intel one to test against, it didn't make this noise when it was new, but that was a long time ago! I didn't think about checking that, so I shall look into it! Would it be worth getting a new AIO if that is the cause? That is something within my range of replacing :P
Depending on when you got it you may be covered by warranty, otherwise yeah a new cooler would be needed. Air coolers wouldn't break down like this so if you do verify that you've got a pump issue, a high quality air cooler would be a good investment instead.
Hi,
My computer is making a noise, but I can't work out what it is, I have powered it on with no fans, and with the GPU disconnected, so neither of these seem to be the issue, but it sounds like the noise of a fan to me. I am using a Corsair AIO for CPU coolings, something like this but without the LED, my system is so old, RGB wasn't even cool.
CPU - Intel Core i5 4670K
Motheboard - ASUS Z87-K
GPU - GTX 980 TI
I have uploaded some wonderful phone quality recording, I'm kind of stuck on knowing what this could be, or how to go about fixing it.
Voice 001_sd.m4a
https://linustechtips.com/topic/1057636-help-computer-noise/
sounds like pump noise from the AIO, any coolers to test against?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1057636-help-computer-noise/#findComment-12508162
https://linustechtips.com/topic/1057636-help-computer-noise/#findComment-12508172
Primary PC:
PSU tier list
https://linustechtips.com/topic/1057636-help-computer-noise/#findComment-12508196
I think the warranty is expired, I got it around 5 years ago, the only thing I have replaced since then is the graphics card. I'll look into air coolers as well, if it turns out to be a pump issue. Thanks for the help!
https://linustechtips.com/topic/1057636-help-computer-noise/#findComment-12509481
Aio's are only meant to last around 6 - 7 years.
Either they break, or the liquid permeates the tubes.
It's not a race to the bottom.
https://linustechtips.com/topic/1057636-help-computer-noise/#findComment-12509697
