Help needed with PSU! RMx
Go to solution Solved by LukeSavenije,
that calculator is overestimating anyways
550 is fine
I need help choosing a PSU. I have read around the forums and i think i have the idea of what i need but i need to ask what wattage i would require as the Coolermaster power supply calculator is down. I have decided to go for a RMx by Corsair but not sure if i should go for a 550 650 or 750? Thanks :)
RM550x is £77.98
RM650x is £95.99
RM750x is £96.99 (Usual Price £114.74)
Here is my build
Ryzen 7 2700x (Stock Air Cooler)
Gigabyte X470 Motherboard
Patriot Viper 3000mhz DDR4 16GB RAM
Gigabyte Windforce RTX 2060
Kingston 240gb NVMe
Seagate 2TB HDD 7200RPM
3 Thermaltake RBG Fans
3 Corsair HD120 Fans
4 Corsair LED Strips
https://linustechtips.com/topic/1057402-help-needed-with-psu-rmx/
