Hi everyone, so i'm planning on getting a new graphics card but i'm not sure which one yet. I'm currently running a gtx 960, which was doing fine until I was lucky enough to get a 144hz 1440p monitor for my birthday. So I was looking at the RTX 2060 or 2070 but i'm worried that my system will bottleneck.
My current build is as follows:
CPU:Intel i7 6700 3.4GHz
Ram: 8GB DDR3 (Plan  to upgrade soon)
MotherBoard: Gigabyte Technology Co. Ltd. Z170-HD3-CF
I'm open to any suggestions if you think I need to upgrade something else first or go for a different graphics card altogether. I have not overclocked my CPU as I don't really know what to do. Thanks.
https://linustechtips.com/topic/1056992-will-my-system-bottleneck/
At minimum you need a 2070 to drive 1440p with nv panel AA methods turned on and give you a crisp non jaggy experience.  You will hit 144fps but will have dips, but that is what freesync is for.  Your CPU will hold you back tho 3.4Ghz will not cut it.  Also definitely go 16GB RAM with SSD as well.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
depends on the games you play, short answer is the cpu is def a bottleneck and at current prices you wanna look at either the 2060, radeon vii or 2080, not the 2070.
if you are on a tight budget and the monitor isn't anything too special, sell/return it and go for a 1080p/144hz VA panel instead and run a 2060 with it. Even a 2080 will not run some AAA games on 1440p/144hz on high.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
