CPU Fan Error with AIO
Go to solution Solved by Skiiwee29,
8 minutes ago, IGMM said:
I recently just upgraded my case, cpu cooler and motherboard and case fans. I bought asiahorse seiii fans and they only connect to the hub and power. Since I'm also using them on my Kraken x72 nothing is technically connected for a cpu cooler I get a cpu fan error everytime I boot. How can I fix this?
You should have an option in your BIOS to ignore this warning. Generally its found in the fan configuration sections.
https://linustechtips.com/topic/1056461-cpu-fan-error-with-aio/
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1056461-cpu-fan-error-with-aio/#findComment-12497893
