So i have 3x4gb sticks of ram but the middle (b channel) slot does not detect any memory (the modules are not faulty) i sprayed them out with compressed air and changed my bios back to the defaults and even downclocked them from 1600 to 1066. Hope someone has a helpful answer. (My mobo is a GA-X58-USB3)
Current main PC:
CPU: R7 7800x3d (PBO undervolted)
GPU: 7900XT
RAM: 32gb Gskill Ripjaws S5 6000mhz
MOBO: Asus TUF B650e wifi
CASE: Xtia Xproto ATX
Server PC:
CPU: Xeon X5690
GPU: R9 Fury X
RAM: Assorted 4gb sticks (24gb total)
MOBO: Asus Sabretooth X58
CASE: Alienware Area 51 ALX
https://linustechtips.com/topic/1055763-x58-ram-detection-problem/
check the CPU mounting and the pins, otherwise it's just getting old and starting to fail.
Desktop benching:
As Jurrunio said it's probably just failing. It's almost 9 years old and has seen a few different PSUs. Maybe one overvolted that DIMM slot. Only way to truly test would be a multimeter or some other device.
CPU: Ryzen 5 2600 4ghz @ 1.35v  CPU Cooler: Mugen 5 Rev b  Motherboard: MSI B450 Gaming Pro Carbon  GPU: Zotac RTX 2060 +150/+1000 Memory: 16GB Viper 4 @ 3200 CL14 Samsung B-die  Storage: 1TB Patriot VPN100 NVMe; 500GB 860evo; 128gb 840pro CaseCooler Master Q500L  PSU: CX750M V2 Operating System: Windows 10 Pro Other: 6 Corsair LL Fans; 2 aRGB Strips
Really? Well sh*t
Current main PC:
GPU: 7900XT
Server PC:
CPU: Xeon X5690
GPU: R9 Fury X
Wait are you saying my cooler it too tight?
Current main PC:
GPU: 7900XT
Server PC:
CPU: Xeon X5690
GPU: R9 Fury X
tight is not a problem, though not tight enough could be as pins could lift off from the contact pads
Desktop benching:
