The one from ebay is bigger, so it will perform better. Otherwise they are both aluminium heatsinks which means that if they would be the same size they would perform equal.
But if you get the ones from ebay you should defenitely use some kind of thermal interface material (thermal pad, thermal paste, etc.) because otherwise they would have little to no effect.
