1 minute ago, Charmander said:
Hi Everyone,
I've been wanting to upgrade my graphics card but I need a new PSU. I was looking at 500W and 80+ Bronze, for example the EVGA 500B, but the prices have gone up a lot recently.
Should I go for it or wait? (BTW I'm in Canada)
Thanks, Charmander
What graphics card are you looking at going to? Whats is your system current specs? PSU prices have been pretty steady recently.
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
https://linustechtips.com/topic/1055093-psu-prices-going-up/#findComment-12485479
Exploring other options might be a good idea, have you checked out the PSU tier list?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1055093-psu-prices-going-up/#findComment-12485483
Thanks for replying
I was thinking for either a GTX 1660ti or RX 580 8GB.
Specs:
https://linustechtips.com/topic/1055093-psu-prices-going-up/#findComment-12485512
Thanks for your reply
Whats the PSU tier list?
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1055093-psu-prices-going-up/#findComment-12485518
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1055093-psu-prices-going-up/#findComment-12485525
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1055093-psu-prices-going-up/#findComment-12485530
9 minutes ago, Charmander said:
Go for 16GB RAM Kit oh wait looks like you have you listed it twice.  Go with the 580, best bang for your buck.  Other then that everything looks good.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1055093-psu-prices-going-up/#findComment-12485536
Just now, Turtle Rig said:
Go for 16GB RAM Kit oh wait looks like you have you listed it twice.  What video card you want ?  Other then that everything looks good.  I would grab the 580 as suggested above.
Thanks for the Reply
I want a 580 or 1660ti
I'm looking for a budget PSU in Canadian Dollars
https://linustechtips.com/topic/1055093-psu-prices-going-up/#findComment-12485541
Grab the 580 and if you overclock it which Im not saying fo you to do but it reaches almost 590 levels of performance.  Forget the 1660Ti its a good card but more of a consumer card not a pro gamer card.  Once again please grab the 580 you wont be disappointed.
https://linustechtips.com/topic/1055093-psu-prices-going-up/#findComment-12485547
I definitely will go for a 580 or if I can wait I will go for the next gen Navi cards
My issue right now is the Power Supply
https://linustechtips.com/topic/1055093-psu-prices-going-up/#findComment-12485554
14 minutes ago, Charmander said:
https://ca.pcpartpicker.com/product/zNK7YJ/evga-power-supply-100b10500kr
Would you think this is worth it? If you see the price history it used to be 40$
Or this https://ca.pcpartpicker.com/product/FdRFf7/corsair-cx-2017-550w-80-bronze-certified-atx-power-supply-cp-9020121-na
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1055093-psu-prices-going-up/#findComment-12485567
What difference does it make if a $10 PSU costs $40 or $60? You shouldn't buy the EVGA B1 either way, as both of those prices are crap for what you get.
The CX550 is available for $55 after rebate, and the Formula 550W is available for $90 without rebate.
https://linustechtips.com/topic/1055093-psu-prices-going-up/#findComment-12485575
Thanks for the reply
I don't really know much about PSU's but are there any benefits other than reliability for the CX550?
https://linustechtips.com/topic/1055093-psu-prices-going-up/#findComment-12485586
I did see this, I guess I should go for it then. Hopefully its better than the 500B
Just remember the PSU in the heart of your system for power you don't want to go super cheap. It will nip ya in the rear in the long run.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1055093-psu-prices-going-up/#findComment-12485588
I guess I got lucky cause  I've been using the Cooler Master TC102 Combo for about 5 years now
https://linustechtips.com/topic/1055093-psu-prices-going-up/#findComment-12485589
The B1 is group regulated, so it's not suited for modern systems. It also has a lot more ripple. It's louder than the CX550, and it uses a sleeve bearing fan. And it's more likely to have coil whine with higher end GPUs, due to the design of the PSU.
Edited by seon123
Something something
https://linustechtips.com/topic/1055093-psu-prices-going-up/#findComment-12485594
Not to mention the cables just look 100% better. You won't have a rainbow of cables.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1055093-psu-prices-going-up/#findComment-12485601
Just now, seon123 said:
The B1 is group regulated, so it's not suited for modern systems. It's louder than the CX550, and it uses a sleeve bearing fan. And it's more likely to have coil whine with higher end GPUs, due to the design of the PSU.
Thanks for the help, I've been using the Coolermaster TC102 Combo for about 5 years so i never experienced a good PSU.
Going to order the CX550 soon!
https://linustechtips.com/topic/1055093-psu-prices-going-up/#findComment-12485604
Yea, I was thinking about cable extension to get rid of the ketchup and mustard. Also planning on getting the Thermaltake Versa H18 Temper Glass with RGB fans.
https://linustechtips.com/topic/1055093-psu-prices-going-up/#findComment-12485610
