Have you tried using OpenVPN?
https://linustechtips.com/topic/1054575-self-hosted-vpn-help/#findComment-12480889
3 hours ago, Snotrap said:
Hello fellow tech heads,
I am curious as to the easiest route to setup a VPN connection to my home network.
I have tried VPN server but no bueno.
Any help is appreciated
Buy a Raspberry Pi, setup OpenVPN by following Youtube instructions or one Github which is called PiVPN
And, if you are not able to connect, use TCP connection instead, but UDP is better overall.
Asus NUC: CPU:i7-4600u | ram: ddr3l 4GB x 2 | ssd: 256GB | Network: RJ45 port, wifi 802.1 ac | usb: USB Gen3 x 4 | SD: SD port x1 | Display: HDMI x1, DP x1| GPU: Intel Graphics 4400 @ 1100Mhz |
https://linustechtips.com/topic/1054575-self-hosted-vpn-help/#findComment-12481214
  • 3 weeks later...
6 hours ago, Snotrap said:
How do I use OpenVPN?
You can set it up using a raspberry pi. There are many guides on YouTube
https://linustechtips.com/topic/1054575-self-hosted-vpn-help/#findComment-12531724
