Hey everyone I'm having problems with this driver. I tried uninstalling and deleting the driver but it just pops up again right after. All my other network adapters work fine it's just the ethernet and I rather use that than wifi. I've tried updating it but it has problems installing
https://linustechtips.com/topic/1054544-ethernet-connection-driver-not-working/
There is another "driver" to install before the ethernet driver.
Go through the troubleshooting, it will say what is needed to be downloaded.
I had the same issue in an older Win installation
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
I ran it through troubleshoot but it said it couldnt identify the problem
