BUILD MY FIRST PC
16 minutes ago, DX547 said:im building my first pc and i wanted to know if this build as any major flaws
if not what might i could upgrade if the specs aren't appropriate
I'm assuming this is a gaming build. Just a few notes, then:
-Replace the S12 PSU with a CXM for the same price. The S12 has had some notable issues.
-Do NOT go with single channel RAM. Go dual channel. There are major performance gains.
- You don't want to pair 2400MHz RAM with Ryzen. Try for 3000MHz as a sweet spot. Also 16 GB would be preferable if you could fit it in the budget.
- For a few dollars more you can go with the 9400F instead for some major performance increases.
-250GB SSD will fill up FAST. I'd go with a 500 at minimum.
Here's a revised build for $65 more, but it has massive performance gains. I kept your choice of tower and GPU:
Here's some relevant videos:
9400F vs 2600:
Single Channel vs Dual Channel:
