1440p ultimate solution
Solved by MeatFeastMan,
Radeon VII. You ideally will want above 8gb for the future at 3440 x 1440. Radeon VII gives you 16gb and HBCC, With the Radeon VII, you don't have to spend crazy money on a 2080ti, but you also get more vram than the 2080, which is okay now but in the future it will struggle with 8gb at ultra. It's the best middleground and the best option for 3440 x 1440.
You should get 60 in every game at ultra, other than maybe one or two that are badly optimized.
