Want to play games like BF4, Crysis, Metro etc.
Have 16gb even though I know its overkill, just don't want to worry about it in the future or anything. ( If i ever wanted to stream and record with fraps nothing major)
http://pcpartpicker.com/user/ELiiMiNaTioN/saved/3uvq
Tell me what you think!
*Plan on getting sp120 quiets* but forgot to add them to build
https://linustechtips.com/topic/105303-gaming-build-first-build/
Just get 2x4 GB, you can get more down the road. Use saved money for case fans.
CPU: i7-4770k CPU Cooler: NH-D14 RAM: Crucial Ballistix Sport 8gb GPU: EVGA Superclocked 780 ti MOBO: ASUS Maximus VI Gene PSU: Corsair RM 850 Case: Bitfenix Prodigy M
https://linustechtips.com/topic/105303-gaming-build-first-build/#findComment-1408201
The H100i will not fit in the Shinobi case at the top. The power supply is too large for a single gpu system. 16GB is overkill, but that's ok if you want to spend the money. I've made a few changes all with the aim of having the budget include an IPS monitor.
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU:  Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
CPU Cooler:  Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($34.98 @ SuperBiiz)
Motherboard:  Gigabyte GA-Z87X-UD3H ATX LGA1150 Motherboard  ($159.99 @ SuperBiiz)
Memory:  Crucial Ballistix Sport 16GB (2 x 8GB) DDR3-1600 Memory  ($134.95 @ Amazon)
Storage:  Kingston SSDNow V300 Series 120GB 2.5" Solid State Disk  ($69.99 @ Amazon)
Storage:  Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($82.99 @ NCIX US)
Video Card:  EVGA GeForce GTX 780 3GB Video Card  ($505.91 @ Newegg)
Case:  BitFenix Shinobi Window ATX Mid Tower Case  ($69.99 @ Newegg)
Power Supply:  Silverstone Strider 600W 80+ Silver Certified Fully-Modular ATX Power Supply  ($85.98 @ Newegg)
Monitor:  Asus VS24AH-P 24.0" Monitor  ($229.98 @ SuperBiiz)
Total: $1597.76
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-01-21 21:20 EST-0500)
https://linustechtips.com/topic/105303-gaming-build-first-build/#findComment-1408575
Total: $1597.76
Thanks for the build, never new that the h100i couldn' fit. Even if there was some crazy way it could I think im gonna look into other cases like the Define R4 and ones that like similar to it.
Reason for the psu of 750w for possible sli and OC but I doubt I would sli, so 600w with OC would be more then enough?
https://linustechtips.com/topic/105303-gaming-build-first-build/#findComment-1409258
Yes, 600W should be fine with an overclock and single gpu.
https://linustechtips.com/topic/105303-gaming-build-first-build/#findComment-1409293
https://linustechtips.com/topic/105303-gaming-build-first-build/#findComment-1430103
