Hi guys thanks for any help.
I just finished my new build custom hard line water cooled. and it looks GREAT but it can't seam to find my RGB controller or the cooler master software is not installing right?
so it does have alot of RGB cpu and gpu blocks. water res top and bottom and 4 fans. the cpu block is in a MB header and works. the 4 fans are all in a corsair lighting node pro and are working. however the gpu block then 2 strips in the res and a outside strip all pluged in to a coolermaster RGB hub can't be controlled. they are all on and sync and rainbowing.  it shows up in devices under mouse, keyboard and pens. as the MasterFan Pro RGB.
only thing i could think of is some kind of control problem because my MB only has 1 internal USB 2.0 port so i'm using a NZXT USB hub to turn 1 in to 3. but my front panel usb is working (headset) and the 3rd is the corsair controller.
Thanks
Caat
https://linustechtips.com/topic/1052999-rgb-controller-not-being-found/
