Right. So I'm having a strange problem with the RGB lit fans in my case.
Story time: I just got a new Phanteks Enthoo Pro M SE PC case today and got everything transferred from my old case and hooked up. Everything looked great. I hooked up the RGB fans in the front and tried out the different setting using the controller button on the front of the case. Again, everything looked great, though I would have preferred to be able to control the lighting with my motherboard like the rest of the lighting in my case, so I tried hooking up the RGB cords to the LED C2 pins on my Aorus Pro Wifi motherboard and launched into RGB Fusion. After trying to play around with the settings and calibrating the lights with varied effects (I could change the color of the fan lights but it wouldn't correspond to what the app was trying to do) I tried to unplug the fan LEDs and discovered that I had messed up the lighting. Turning the LEDs off from the case controller button would change the lights to red instead of turning them off, and instead of the 10 colors that were supposed to show up I'd get a mix of greens, yellows and purples. Unplugging the lights wouldn't reset them and unplugging the power would also do nothing.
I know it's my fault for trying to experiment with the RGB lighting in a  way it wasn't meant to(especially since I knew beforehand the MoBo probably wasn't compatible) but I'm hoping there's some way I can reset the lights. Does anyone know if Phanteks has a way to reset/recalibrate their case lights and/or fan lights?
P.S.
            the pic attached is the light that's supposed to be set to blue (I think...)
https://linustechtips.com/topic/1052971-phanteks-rgb-help-please/
