I have old lenovo G500 laptop today when i was trying to open the bottom lid and was removing the charging socket a small spark appeared after which all of the juice of my laptop drained now it shows my laptop charging but is fixed at 0% (it come from 100%-0 on while charging)it was showing charging and on other side discharging pls help
https://linustechtips.com/topic/1052822-laptop-charging-issue/
sounds like you shorted up the controller inside your battery.
https://linustechtips.com/topic/1052822-laptop-charging-issue/#findComment-12463920
47 minutes ago, abhihere121 said:
What should i do now
get a new battery.
https://linustechtips.com/topic/1052822-laptop-charging-issue/#findComment-12472523
4 minutes ago, Levent said:
get a new battery.
Hey dude today when i was working on my laptop it was on charge it suddenly switched off now the power indicator is not blinking nothing is working i have order a new power socket for my laptop but what is happening
https://linustechtips.com/topic/1052822-laptop-charging-issue/#findComment-12472541
you probably did more damage that I anticipated, when my lenovo g510 shorted out it also had the same symptoms. Its now lying in trash somewhere.
https://linustechtips.com/topic/1052822-laptop-charging-issue/#findComment-12472555
