Lineage OS on Redmi Note 7
Go to solution Solved by v0nN3umann,
With a Xiaomi phone you just need to create an account and then wait a few days (3? I'm not sure) to unlock your bootloader.
And with an unlocked bootloader flashing a custon ROM should be no problem at all.
But make sure to follow instructions of some sort if you are inexperienced, because there are things you could possibly do wrong.
Doei en veel geluk ? (was that correct?)
okey thank you!
