Building a system
38 minutes ago, TJHuck said:That's for win 10. tried to find the least expensive one because I'm cheap and its going to be my first mid-tier gaming pc
How about something like this? The stock 65W cooler on the 2600 is fine, and can be upgraded later. You're not going to have issues during a gaming load. Gigabyte's low end 4 phase VRM is terrible, so I swapped that out. You don't need a 750W PSU. A higher end 550W PSU is plenty, and it will be quieter. Another option for the case is the TT G21 for ~$10 more. Mesh front and TG.
If you want RGB, just add RGB strips with the remainder of the budget. That will give you more lighting for your money.
Instead of WiFi, use ethernet, or if that's not possible, use a powerline system. Either option is much better than WiFi.
https://www.amazon.com/Powerline-Computer-Network-Adapters/b?ie=UTF8&node=1194444
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor ($164.89 @ OutletPC)
Motherboard: MSI - B450-A PRO ATX AM4 Motherboard ($99.89 @ OutletPC)
Memory: G.Skill - Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory ($77.99 @ Newegg)
Storage: Crucial - MX500 500 GB 2.5" Solid State Drive ($66.50 @ Newegg)
Storage: Hitachi - Ultrastar 7K3000 2 TB 3.5" 7200RPM Internal Hard Drive ($53.89 @ Amazon)
Video Card: Asus - Radeon RX VEGA 56 8 GB AREZ STRIX Video Card ($349.99 @ Newegg)
Case: Fractal Design - Focus G ATX Mid Tower Case ($61.01 @ Newegg)
Power Supply: BitFenix - Formula Gold 550 W 80+ Gold Certified ATX Power Supply ($69.00 @ Amazon)
Total: $943.16
Generated by PCPartPicker 2019-04-03 18:09 EDT-0400
