Greeting everyone!
I upgraded my old (1080p 60hz) triple monitor setup.
My new monitors now 1440p/144hz,with HDR400
My problem is the next,the new monitors support HDR,what is work well if I use the monitors as separated screen(how windows set up automatically), until I set the NVsorround settings.
When I setted up the triple monitor settings in the nvidia control panel ( resolution 7680*1440,frequency 144Hz ) and I go back to enable HDR in the Windows I can't do it,cos the Windows not recognize the NVSurround screen as a HDR monitor.
All monitors using different Display Port 1.2 cables.
Monitors: Gigabyte AORUS AD27QD
Vga: Gigabyte Aorus RTX 2080Ti
Latest nvidia driver hotfix (425.11),but I tried with the 419.67 and 419.35 (same problem ),latest Windows 10. (1809). Nvsurround_HDR.png.df615e48b3e5794e474c37b7efa75d54.png
https://linustechtips.com/topic/1050987-nvsurround-hdr-problem/
NVIDIA surround is a piece of broken shit, give up on it would be my advice
Builds:
https://linustechtips.com/topic/1050987-nvsurround-hdr-problem/#findComment-12448626
