so i just got finished building my first ever gound up pc. ive watched alot of videos on what to do next as for boot drive and drivers etc... my question is, can i just plug in my old hdd(storage) and ssd(boot) from the other pc and go from there. ive upgraded pretty much everything except from the storage so id hate to start from zero and lose all the stuff i have from the old rig.
https://linustechtips.com/topic/1050327-first-pc-build/
Should be able to
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/1050327-first-pc-build/#findComment-12443517
-Moved to Storage Devices-
That will work, just make sure your new hardware supports your old OS, run sysprep Generalize(this will clear out any and all drivers), and you should be fine. Also make sure your Windows activation is linked to your Microsoft account, otherwise you will need a new product key.
https://linustechtips.com/topic/1050327-first-pc-build/#findComment-12443525
is there somewhere specific to go for the sysprep? and does it need to be done from the old pc and downloaded onto a usb or done directly to the new pc?
https://linustechtips.com/topic/1050327-first-pc-build/#findComment-12443538
Hit Windows + R on your keyboard.
type in "sysprep" and hit Enter. Run the application in the folder that pops up. You want to Generalize your operating system and shutdown when sysprep is finished. Slap the drive in the new machine, fire it up, and(assuming it's Windows 8 or newer) it'll work perfectly.
https://linustechtips.com/topic/1050327-first-pc-build/#findComment-12443542
you just plug the drive in see if it works,
if not, reinstall windows on new drive/ partition and transfer old data when you have time. prefer not to wipe old drive and use it as slave, till a day you rarely access it
https://linustechtips.com/topic/1050327-first-pc-build/#findComment-12443551
yeah it was windows 10 i recently got an ssd and made it  a boot drive so im relatively up to date with the OS. only problem is that the old pc is out of commission(dissassembled) and used some of the power cables to put into the new pc. is a flash drive ok cuz thats all i have.
https://linustechtips.com/topic/1050327-first-pc-build/#findComment-12443558
9 minutes ago, utopianexile said:
one thing that i was hesitant about was that i went from a intel build to ryzen will that effect anything, figured id ask. not sure what is relevant at this point.
No, it'll be fine anyway
https://linustechtips.com/topic/1050327-first-pc-build/#findComment-12443561
Just move the cables back from the new PC to the old so you can sysprep it, then.
You'll want to shutdown the new system anyway, might as well sysprep it while you have it turned off.
https://linustechtips.com/topic/1050327-first-pc-build/#findComment-12443569
update: so i got it up and running without the sysprep and everything in order to get all the proper drivers and what not do i just need to find them online and have them overwrite the old ones or do i need to wipe the old one first?
https://linustechtips.com/topic/1050327-first-pc-build/#findComment-12446410
Sysprep clears your old drivers. It's recommended to do that whenever you make drastic hardware changes.
That said, you can sysprep from your current system now, just change the option to restart instead of shutdown when sysprep is finished. After that, you can reinstall all the various drivers for your motherboard, GPU, etc.
https://linustechtips.com/topic/1050327-first-pc-build/#findComment-12446420
i did the sysprep and it comes up with "was not able to validate your windows installation review file log at yadayadayada"
https://linustechtips.com/topic/1050327-first-pc-build/#findComment-12446431
Is Windows activated?
https://linustechtips.com/topic/1050327-first-pc-build/#findComment-12446442
yeah i was just using it
Activated is different than installed.
Open Settings and see if it's giving you a thing in the bottom saying "Windows isn't activated"
https://linustechtips.com/topic/1050327-first-pc-build/#findComment-12446447
