If you don't have the ability to make that general decision yourself, don't go CPU surfing. Get a general all around processer:
3 2200g, i3 8100 somein' like that.
Don't forget to quote or mention me
Primary PC:
CPU: i5-8600K @Stock  GPU: RTX 2060 Zotac GAMING Amp  RAM: 4x4GB 2400 MHz DDR4 Crucial Ballistix Sport LT  MOBO: Asus Prime Z390-A  HDD: 4 TB 5400 RPM Seagate Barracuda, 2TB 7200 RPM Seagate Backup Plus Ultra Slim  SSD: Inland Professional 120 GB  Soundcard: built in  Case: NZXT H500i  Screen: HP 22cwa IPS
Server: Working on it (See https://linustechtips.com/main/topic/1039535-server-build/)
Laptop : Microsoft Surface Pro 5:
CPU: i5-7300U  GPU: Intel HD 620  RAM: 2x4GB DDR3 1866 MHz  MOBO: Microsoft Custom  SSD: Internal M.2  Soundcard: built in  Case: lol its a laptop  Screen: see case: lol its a laptop
Phone: Google Pixel:
CPU: Qualcomm 821  GPU: Adreno 530  RAM: 4GB LPDDR4X  Storage: 32GB eMMC  Display: 5" 16:9 1080x1920p Corning Gorilla Glass 4
Dog: Shorty, Absolute Mutt:
Ears: Floppy  Tail: Long  Paws: Muddy  Fur: Brown
Cats: Chili and Cheddar (Don't Ask):
Cute: Yes  Fur: Soft  Tail: In front of you whacking your face
Cereal:
Dry: NOPE  With Milk: Cinnamon Toast Crunch  Milk: Whole % Vitamin D  Hot: Quaker Instant Maple  Steel Cooked: Wegmans with Sweetened Condensed Milk
Coffee:
Type: Latte  Caffeinated: very much so  Milk: Yes
Game consoles:
PC ALL THE WAY
https://linustechtips.com/topic/1050253-cores-or-clock-speed/#findComment-12442672
23 minutes ago, Snipergod87 said:
Do you have any specific CPU's in mind?
My first option was the ryzen 7 2700X
Money isn't the problem, even though a 7 2700X might be a little overkill
Not fast enough
https://linustechtips.com/topic/1050253-cores-or-clock-speed/#findComment-12442674
Just now, Ninthendo64 said:
Not fast enough
For productivity & webbrowsing?
Primary PC:
Cereal:
Coffee:
Game consoles:
PC ALL THE WAY
https://linustechtips.com/topic/1050253-cores-or-clock-speed/#findComment-12442685
7 minutes ago, Ninthendo64 said:
You don't need Ryzen 7 for that.
Is it going to do any gaming at all? If so build an R3 2200G APU machine with some 3000mhz RAM, what are you doing that an R3 2200G isn't fast enough?
If not then just buy any old laptop with an SSD, or used business machine with an SSD for $200 or lower.
https://linustechtips.com/topic/1050253-cores-or-clock-speed/#findComment-12442686
Your go to CPU will be the 2200G or 2400G.
Buying a 2700x would involve buying a GPU
https://linustechtips.com/topic/1050253-cores-or-clock-speed/#findComment-12442689
No gaming
https://linustechtips.com/topic/1050253-cores-or-clock-speed/#findComment-12442692
Thanks Golden. I forgot about the no iGPU part. I ought to keep that in mind. @Ninthendo64 A Vega 8 will be faster than a 710 or 1030 any day
17 minutes ago, Ninthendo64 said:
No gaming
Okay, but you tell us simple, than you tell us OP, then you tell us no gaming. I'm sorta confused. Is this machine supposed to be high powered?
Primary PC:
Cereal:
Coffee:
Game consoles:
PC ALL THE WAY
https://linustechtips.com/topic/1050253-cores-or-clock-speed/#findComment-12442695
No gaming
so you're doing no gaming and light web browsing/spreadsheet work? I think a dual core would be fine, a pentium or athlon would serve you well.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1050253-cores-or-clock-speed/#findComment-12442699
No gaming
Then you don't need a desktop PC at all even. Or if you want one just get a used business machine that's cheap and throw an SSD into it
this one's $200 for a 4th gen i7
https://www.ebay.com/itm/Dell-Optiplex-9020-SFF-i7-4770-3-4GHz-8GB-RAM-500-GB-HDD-Windows-10-Home/233105231477?hash=item3646278e75:g:g1kAAOSw76lcAAY6
https://linustechtips.com/topic/1050253-cores-or-clock-speed/#findComment-12442700
But what is better now?
Cores or Clock speed
It doesn't matter for your use case
otherwise it depends on the software, if Blender it loves cores, if gaming 5ghz is better than 4ghz in general.
https://linustechtips.com/topic/1050253-cores-or-clock-speed/#findComment-12442708
Honestly it doesn't really matter in real world performance.I would say technically cores for multi tasking but as long as you don't have like 100+ chrome tabs open it won't really matter.RAM would also play a much larger part in the equation tho
My life
https://linustechtips.com/topic/1050253-cores-or-clock-speed/#findComment-12442710
For "E-mail, Microsoft-Office, browsing".
4+ cores,high clockspeed, but you could do those things on a potato, so there is something you are not telling us.
What else are you doing on your pc?
I only see your reply if you @ me.
https://linustechtips.com/topic/1050253-cores-or-clock-speed/#findComment-12442711
710? yes. 1030? no way.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1050253-cores-or-clock-speed/#findComment-12442712
It doesn't really matter is what we're saying. That's why CPU mfrs moved away from GHz naming schemes! Just take an expert's recommendation.
PCPartPicker part list: https://pcpartpicker.com/list/b6bfbX
Price breakdown by merchant: https://pcpartpicker.com/list/b6bfbX/by_merchant/
CPU: AMD - Ryzen 3 2200G 3.5 GHz Quad-Core Processor  ($93.99 @ SuperBiiz)
Motherboard: ASRock - B450 Pro4 ATX AM4 Motherboard  ($64.99 @ Newegg)
Memory: Crucial - Ballistix Sport AT 8 GB (1 x 8 GB) DDR4-3200 Memory  ($51.96 @ Amazon)
Storage: Samsung - 860 Evo 250 GB 2.5" Solid State Drive  ($57.89 @ OutletPC)
Storage: Seagate - Barracuda 1 TB 3.5" 7200RPM Internal Hard Drive  ($38.89 @ Amazon)
Case: NZXT - H500 (Black) ATX Mid Tower Case  ($75.99 @ B&H)
Power Supply: Corsair - CXM (2015) 450 W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($34.98 @ Newegg)
Total: $418.69
Generated by PCPartPicker 2019-03-31 16:10 EDT-0400
Primary PC:
Cereal:
Coffee:
Game consoles:
PC ALL THE WAY
https://linustechtips.com/topic/1050253-cores-or-clock-speed/#findComment-12442713
I thought about going with 16GB 3000MHz
Total: $418.69
Thanks
Nah i just wanna build an expensive office PC
https://linustechtips.com/topic/1050253-cores-or-clock-speed/#findComment-12442716
Thanks
This is a base suggestion. Consult others. if you are in the US, visit Micro Center. They're great. Also, if money isn't a factor, there are also some things that can be changed, like dual-channel RAM. Ask around IRL, but you could try this.
Primary PC:
Cereal:
Coffee:
Game consoles:
PC ALL THE WAY
https://linustechtips.com/topic/1050253-cores-or-clock-speed/#findComment-12442726
Thats kinda overkill.
Just buy a used optiplex and SSD and call it a day
If your in a office all day put that extra money towards a better chair or a ergonomic keyboard and you'll pribaly get more benefit
My life
https://linustechtips.com/topic/1050253-cores-or-clock-speed/#findComment-12442728
Thx
Despite the fact that ist total overkill, if i were to pick between the ryzen 7 2700 and an i7 7800 which one should i go for?
https://linustechtips.com/topic/1050253-cores-or-clock-speed/#findComment-12442734
2700 but if you have your mind set on this overkill just get whichevers cheaper
My life
https://linustechtips.com/topic/1050253-cores-or-clock-speed/#findComment-12442747
There isn't much point in spending more than you need to.
There's two options that would be perfect for your use case without spending more money than you need to: @AKinsey2468's build list or a used office PC from eBay. Both would do the job absolutely fine.
You can go and build a PC which is absolutely overkill, that's fine by me, but personally I don't think it's worth it.
For your use case, none of them matter. Web browsers and Microsoft Word are both very easy things for a PC to run so clock speeds and core counts make no difference.
https://linustechtips.com/topic/1050253-cores-or-clock-speed/#findComment-12442755
Why it's so hard for you to admit that it's for gaming? No shame on that.. just say it..
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
https://linustechtips.com/topic/1050253-cores-or-clock-speed/#findComment-12443230
