Hey everyone, I'm planning on making this my first build and I would like some opinions on it, any and all opinions are appreciated.
Case: Sharkoon DG7000-G RGB
Extra cooling: /
Optical drive: LiteOn iHAS324-07
Motherboard: ASUS ROG Crosshair VII Hero Wi-Fi, socket AM4
CPU: Ryzen™ 7 2700X
CPU cooler: Wraith Prism Cooler (standard)
Thermal compound: Thermalright Chill Factor 3
Graphics card: ASUS GeForce RTX 2070 ROG STRIX OC GAMING
or GIGABYTE GeForce RTX 2070 GAMING OC 8G
Ram: G.SKILL TridentZ RGB Series 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200
Storage: Hard Drive:
sata: WD Bleu 2Tera
SSD:
M.2: Corsair Force MP510 M.2 2280 480GB PCI-Express 3.0 x4, NVMe 1.3
Sata: WD Blue 3D NAND 1TB PC SSD - SATA III.
Power supply: be quiet! Dark Power Pro 11 750W
Operating System: Windows 10 Pro
PC partpicker list: https://pcpartpicker.com/list/P8BJr6
https://linustechtips.com/topic/1049851-my-first-build/
12 minutes ago, Draiga said:
Ram: G.SKILL TridentZ RGB Series 64GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200
What do you need 64GB of RAM for?
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/1049851-my-first-build/#findComment-12439513
And I made a mistake, I meant 32GB
Do you already own that case, as it looks a bit cheap for a budget like this ? I would look at the ASRock X470 Taichi, Gigabyte X470 Gaming 7 and MSI X470 Gaming M7 as some alternative high end boards. Nothing wrong with the CHVII though.
Are you getting an aftermarket cooler ? No point getting thermal paste if not. Again for a build like this I would put a cooler in there.
What is your budget for the pc ?
https://linustechtips.com/topic/1049851-my-first-build/#findComment-12442781
I actually like how the case looks compared to the other ones i found that were suitable for my build, and I read pretty good reviews about it. I did consider the "be quiet! DARK BASE PRO 900" as a case but quickly chose the Sharkoon looking at the price difference. You have any suggestions for another case maybe?
And I'm not planning on overclocking right off the bet, so I decide to keep the aftermarket cooler as an upgrade for later. Plus, I like the looks of the Stock cooler coming with the Ryzen 7 (Wraith Prism)
And as for budget, I'd definitely like to keep it below €2000. But I also think it's worth spending a bit more if it means I'm 'Future proof', so to speak.
(That's one of the reasons why I'm going for the Ryzen 7, not the 5. And why I'm taking 2X16 GB ram instead of 2X8)
https://linustechtips.com/topic/1049851-my-first-build/#findComment-12444817
