I got an xfx rx480 RS. now that card is known for having a bad cooler, and it does. mine are at an average 40c on idle with only wallpaper engine running. So im looking for a new cooler for it. Are there any coolers i can buy online or are it only DIY? I would like to have a air cooled one cuz my case doesnt support water cooling unless its like those with 1 fan on the radiator (i think its 120), as i will be able to put it on the back of my case. Ive seen some custom coolers but i worried they either wont fit or it will be too big for it. And ive seen coolers but those only come with the heatsink and then u need to buy a seperate water cooling.
https://linustechtips.com/topic/1049510-rx480-cooling/
What temps do you hit on load?
https://linustechtips.com/topic/1049510-rx480-cooling/#findComment-12436916
