I've currently got 2x4gb corsair vengeance ddr3 1600mhz installed in my system and would like to upgrade it to 16gb. I know that if I install sticks that are faster they will automatically be underclocked to the slowest speed ram, but I'm wondering how important it is to match the timings/ latency/ voltage to my existing ram for system stability?
i5-3570K @4.3GHz Turbo w/ auto voltage
MSI Z77A-G45
Vengeance LP 2x4GB DDR3 2200MHz CL13
STRIX GTX 970 +180MHz Core clock +400MHz Memory Clock
MX500 500GB
CM h212+ w/ Cougar Vortex PWM 120mm @850 rpm
Lamptron FC9 \\ Cougar Turbine 120mm (4-pack) @800 rpm \\ NF-A12x15 PWM @1000 rpm
Antec One
Windows 10 Home
____________________________
ASUS VG248QE 3D @144Hz
G710+ w/ Corsair PBT doubleshot keycaps + Double o-ring mod \\ G502 Spectrum
AKG K240 Studio w/ FiiO Olympus \\ Logitech X-530 + X-240 = Ghetto 7.1
https://linustechtips.com/topic/1049433-need-help-upgrading-ram/
I mean, i had a load of ram kits in my life on this rig
It is VERY important that you get the timings right, if you don't it will bluecreen like crazy on you, the voltages are kinda the same across the board i wouldn't worry that much about them but i'd just recommend buying a 16gb kit of RAM of the bat. It isn't worth it to mix and match RAM sticks it's just too much of a headache
do you think there's still cause for concern if I can get the exact same 2x4gb kit? Or corsair also had a low profile version of the same kit that I was looking at for clearance reasons with my sink. Have you tried matching regular with low profile kits of the same model? It would be ideal for me if I could get the low profile version and avoid having to replace my heatsink as well.
MSI Z77A-G45
MX500 500GB
Antec One
Windows 10 Home
