PC Spec :
i5 2400 3.10 GHz
Gpu: rx 560 XFX 2Gb VRAM with 6 pin power (the old one)
Psu: EVGA 400W N1
Motherboard : asus p8h61-m lx r2.0
Ram : 8gb DDR3
So i bought a new gpu which is GTX 1060 3gb Inno3d 2nd hand, when i install it, nothing happen the pc won't booting up and then i unplug the cable power and replug it suddenly after i press the power button the gpu (gtx 1060), a small fire appears from it , and followed by little smoke and i unplug the power cable. Im so scared to turn it on again, then i change the graphic card with my gpu (RX 560). After i install it, the pc works just fine and nothing happen with the PCie.
So what caused of the problem? is it from the gpu or the motherboard or even my psu? Please guys i need your help??, im scared if i buy another one, it will happen again and i hope the problem was from the gpu
https://linustechtips.com/topic/1048406-gpu-with-little-fire/
Can you attach a picture of the graphics card where the fire happened?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1048406-gpu-with-little-fire/#findComment-12427420
for now the gpu is not with me, and idon't really remember where the fire appeared even theres no mark on it, all i remember is the fire appears on the board of the gpu, not from the inside of gpu
https://linustechtips.com/topic/1048406-gpu-with-little-fire/#findComment-12427452
3 minutes ago, LukeSavenije said:
why do i think this is the problem?
after that, my pc works just fine without that 1060, even that psu meets the minimum for this card, if the psu was the problem im sure the other components will get the impact. wht do u think?
https://linustechtips.com/topic/1048406-gpu-with-little-fire/#findComment-12427458
It's not a particularly high quality unit, even though on paper it's enough to power the system, it's rather cheap.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1048406-gpu-with-little-fire/#findComment-12427466
I'm not saying wattage... I'm talking quality
that's a way of saying it, i'll do it the other way: It's crap and you should swap it, it might even have caused that small fire
https://linustechtips.com/topic/1048406-gpu-with-little-fire/#findComment-12427533
3 minutes ago, timi123 said:
Just because one person says it's okay, doesn't mean it's okay.
And just because something can do the job, doesn't mean it is going to do it well or do it for very long.
The PSU is a HUGE place to not cheap out on.
"Liam" - CPU: Ryzen 3700x Base GPU: EVGA Titan X(Maxwell) RAM: Trident Royal Z 32GB @ 3600mhz Case: Lian Li PC-O11 Dynamic White Cooler: Corsair H150i Pro RGB 360mm Case Fans: Thermaltake Riing 12 Series Whitex6
https://linustechtips.com/topic/1048406-gpu-with-little-fire/#findComment-12427687
Because it probably is.
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/1048406-gpu-with-little-fire/#findComment-12427693
1 hour ago, timi123 said:
Psu: EVGA 400W N1
  Reveal hidden contents
Why am I not surprised?
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
https://linustechtips.com/topic/1048406-gpu-with-little-fire/#findComment-12427707
