should be no noticeable load taken from the cpu, however the important thing to know is are you using headphones (and what are they?) or speakers?
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
https://linustechtips.com/topic/104840-sound-card/#findComment-1401880
Sound cards do not affect how the sound is weighed on the CPU. Nor do they do pretty much anything. So no. Dont get it.
My Build Log on PCPartPicker FX-6300, ASUS M5A78L-M/USB3, MSI 7870 GHz Edition, Corsair Vengeance LP 1x8GB, 1TB WD Blue, Fractal Core 1000 USB 3.0, Corsair CX600, and my most recent addition that I've had forever and isnt new is a 80GB WD800 for Linux, Lenovo ThinkPad X131e, ASUS Transformer TF300T, Galaxy Note 3 Sister dropped it in a puddle I now have to use a Samsung Brightside, Beyerdynamic DT990 Pro 250ohm version, Blue Yeti  #TheRealKEH-JEFF | "Sometimes, if were lucky, in Australia, a family has 2 kangaroos to pick up the kids with" - marto | Your entry here | Remember kids; just because Linus has a video on it, doesn't mean that its the best choice | ts3.wferr.com the best TeamSpeak Abide by the CoC | Looking for build help? Read this before posting |
https://linustechtips.com/topic/104840-sound-card/#findComment-1401892
no mater what other say. this can improve you sound quality(depending on the speakers or the headphones/headsets you are using)
you will have much more control with the asus software and also get virtual surround 5.1(which i use a lot to watch movies with my headset)
so yes this can be useful for you
https://linustechtips.com/topic/104840-sound-card/#findComment-1401939
Guy's we still don't know what headphones (if any) he has,  so any advice  is kinda silly.
https://linustechtips.com/topic/104840-sound-card/#findComment-1401942
I haven't purchased headphones yet. I am purchasing this soundcard when I purchase my upgraded motherboard & new thermal paste so they all come together. I will then look into headsets over the next few days.
The most important part of any audio setup is the transducers at the end, in other words buy your headphones or speakers first, then match your sound solution to them.
Not the other way around.
EDIT: an example of why would be if you bought the xonar card now, then you would be limiting your choice of headphones to 80ohm+ in order to maintain FR.  If you buy a dac now then you are limiting yourself to non usb headphones etc.   Not that I recommend usb headphones very often but you get the point. :)
https://linustechtips.com/topic/104840-sound-card/#findComment-1402240
