I recently came into ownership of a nice 1920x1080p monitor, but that's pretty much all I know, other than it's probably old since it only has a VGA and DVI-I Dual Link inputs. I'm having troubles getting it to output. I think it might be due to using a DisplayPort to VGA adapter, but I would like to know for sure and if it is because of the adapter, one that might work better.
Also, even though it's a minor problem since I'm only using this one for Discord, why is there horizontal lines going up and down the screen? I this also from VGA? Or might it just be the monitor?
https://linustechtips.com/topic/1047569-display-not-working-pls-help/
So you going from DVI to DVI - HDMI converter to video card ?
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
1 hour ago, OtterlyDumb said:
It's, from the video card, DisplayPort to VGA to the display
Why not monitor DVI to video card DVI display port converter ?
15 minutes ago, OtterlyDumb said:
Because I have another monitor connected to the DVI
You can't have your cake and eat it too.  You will have to choose which monitor you want to use, apparently it is not going to happen with the VGA connection.
