basically i want to buy a new pc ryzen 2600 b450m pro4 with 8gb 3000 mhz of ram but i only have £500. is 8gb enough to play any game without any issues bare in mind i only play games on the lowest settings 1080p and maybe in some game ill have only the texture on high but everything on low. and im just asking if i should go with 16gb or 8gb
https://linustechtips.com/topic/1047370-is-8gb-enough/
It's 2019, 16Gb of RAM is a must.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1047370-is-8gb-enough/#findComment-12418769
@Alwaroo
Are you aware that the Ryzen 2600 doesn't have an iGPU?
8GB should be enough for most games, but for new AAA titles you might have some trouble, it's recommended to get 16GB but it depends on the games you usually play, I don't think graphics settings affect RAM usage much, if at all.
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/1047370-is-8gb-enough/#findComment-12418772
1 minute ago, _Syn_ said:
@Alwaroo
ik im planning either a new rx 580 or a used gtx 1070
https://linustechtips.com/topic/1047370-is-8gb-enough/#findComment-12418776
Rust is such a bad example tbh, people are reporting memory leaks and excessive memory use in general (10-14GB). I would definitely get 16GB of RAM (2*8GB) and save in the GPU-department, seeing that Rush runs on a toaster. You could pick up some ~R9 280 for $50 and save for a better GPU.
https://linustechtips.com/topic/1047370-is-8gb-enough/#findComment-12419117
