Looking for some build advice, haven't been gaming for a while so my build fell behind a lot. Wondering if I would need to start all over or a few parts here and there to get her back up in shape. Mostly planning to run Nox emulator(Android emulator) and a few games like Civilization, Warcraft(remastered) and maybe get back into WoW. Current build runs Civ decent but Nox destroys my CPU - running at 70+%
Any advice is helpful. I definitely cheaping out on my cooling back in the day :-(
Current Build:
CPU:   Intel Core i5 4670k CPU @3.40GHZ
MoBo: ASUSTeK Z87-A
RAM: DDR3 16 GB(4) - G.Skill
GPU: GeForce GTX 770
Power: 750W
Cooling: Corsair H60
https://linustechtips.com/topic/1047042-look-for-build-advice/
7 minutes ago, LukeSavenije said:
hm... whole system upgrade?
any budget in mind?
Would like to avoid a whole system upgrade but  my current budget would be around 600-700$.
Powersupply: Thermaltake Smart 750W 80+ Bronze ATX 12V 2.4/EPS 12V 2.92 Power Supply SP-750PCBUS
https://linustechtips.com/topic/1047042-look-for-build-advice/#findComment-12416253
yeah... that one needs a chance then
you could look into a 4770k or 4790k, but i would consider a path to ryzen, a 2600 with a good b450 board should work great
i suggest you look into the motherboard tier list if you do want to go to ryzen, and the psu tier list to select a new psu of at least 500 watts tier budget or higher
both lists can be found in my signature
https://linustechtips.com/topic/1047042-look-for-build-advice/#findComment-12416260
