Hi there
Just finished building a lackrack and homelab. Need to get some rackmount powerstrips preferably with surge protection.
Are these any good? https://www.amazon.co.uk/Dynamode-Horizontal-Switched-Distribution-Protection/dp/B0080OISQQ/ref=sr_1_2?ie=UTF8&qid=1553197241&sr=8-2&keywords=rackmount+power+strip
Also is there any advantage of using IEC-320 C20 like on the apc units over 3pin uk plugs on the above?
Thanks in advance
Server 1:  CPU: i3 2100T  SSD: 840EVO MOBO: DQ67OW NIC: i340 -T4
Server 2:  CPU: Pentium D  MOBO: Dell Dimension 5150
Switch 1: Netgear GS108
Switch 2: Cisco 3500
https://linustechtips.com/topic/1046835-power-supply-help/
