Is there a difference between these modules?
Go to solution Solved by Jurrunio,
try reset cmos, either take out the battery or short the correct pins
https://www.kingston.com/datasheets/kvr1333d3n9_4g.pdf
https://www.kingston.com/datasheets/kvr13n9s8_4.pdf
I cant run these memory sticks together and I don't really get why. The pc wont even boot properly so it doesnt let me get to the bios settings
https://linustechtips.com/topic/1046562-is-there-a-difference-between-these-modules/
Desktop benching:
it didnt work by reseting. I had another stick of the same speed lying around, an unusual brand module from Dynet and it worked. I think the kingston stick is dead maybe, kind of weird since I pulled it out from a working system
