Need help choosing a cpu for server
Solved by Electronics Wizardy,
Just now, Bajantechnician said:Gotcha. What would you recommend between the dual xeons and a 1950x? The pricing comes out to be approximately the same
Id personally go with the dual xeons as you get much more ram that is cheaper. You will probably be ram limited before your cpu limited here.
Im guessing you will need 128gb of ram, probalby 256gb will be nice.
What are you doing for storage? Id get a few big ssds for the vms.
