pls I need some math help
Solved by Dash Lambda,
This looks like a homework problem. I'll explain what you're doing at each step using an arbitrary function f(x).
Reflection about the y-axis: You're flipping the direction of the x-axis, so f(x) -> f(-x).
Translate 5 to the right: You're moving it along the x-axis, which means you're changing x again, so f(x) -> f(x - 5).
Translate 3 down: Now you're moving it along the y-axis, which means you're modifying y, and the function itself is your y coordinate, so f(x) -> f(x) - 3.
Compress vertically by 1/2: You're squishing the function so it's half as tall, so f(x) -> f(x)/2
