Need help with new cpu and gpu
Go to solution Solved by Streetguru,
14 minutes ago, pilllowpants said:
That's not too great a price for Vega 56
And if you only have a 1080p 60hz display an RX 580 is plenty
That's a horrible price for such an old i7
For that same $500 you can get an R7 1700 with 16GBs of RAM and an RX 580 8GB which is on sale atm
PCPartPicker part list: https://pcpartpicker.com/list/zVqMWD
Price breakdown by merchant: https://pcpartpicker.com/list/zVqMWD/by_merchant/
CPU: AMD - Ryzen 7 1700 3 GHz 8-Core Processor  ($158.89 @ OutletPC)
Motherboard: Gigabyte - B450 AORUS M Micro ATX AM4 Motherboard  ($74.99 @ Newegg)
Memory: Team - Vulcan 16 GB (2 x 8 GB) DDR4-3000 Memory  ($84.89 @ OutletPC)
Video Card: ASRock - Radeon RX 580 8 GB Phantom Gaming X Video Card  ($169.99 @ Newegg)
Total: $488.76
Generated by PCPartPicker 2019-03-19 22:21 EDT-0400
I read the 3570k will bottleneck the vega
yes unless you're at 4K
Desktop benching:
6 minutes ago, pilllowpants said:
hey i wanna update my 770 4gb to vega 56
i have i5 3570k cpu
also i have asrock z77 exteme 4 mobo
got 750w power supply
Thanks not sure if i posted this in right section didnt see no were else to post this
What's your budget? And how much is that Vega 56 card?
2 minutes ago, AGoodSword said:
i would upgrade your cpu to a i7 3770k and then the bottleneck should be less (cause you have 8 threads)
Not very worth it unless that i7 is nearly free.
vega 56 is $319 on newegg
I can get i7 3770k used $259 can afford that Next payday
could getting new amd mobo and cpu be cheaper?
I see some low prices amd mobos and cpu on newegg
amd FX-8350 like $65 on newegg Not sure what mobo is needed for this
Btw I got ddr3 ram
I may just get vega 56 and bottleneck for now
would that still get more fps than rx 580
Sorry for late reply had to run to gas station get some peanuts
next payday my budget will be like $500
Total: $488.76
will this cpu work with that mobo says am3+ its alot faster and cheaper than i7 1700
https://www.newegg.com/Product/Product.aspx?Item=N82E16819113284
If so ill go with everything you picked and replace gpu with vega 56
was looking at fps test on build you sent me its like 40 more fps on witcher 3 than my setup
its a little bit more expensive will this work it says it will
your actually slow in the head.... the i7 3770k is on par with 7th gen i5's and it is worth it
If a game doesn't really use more than 4 threads that "upgrade" isn't really worth it, and if he only has a 60hz display the i5 isn't much of a bottleneck if it's overclocked.
