Hi guys, I will be upgrading my system soon and have an issue to resolve. currently am running an old HD7770 from XFX and I will upgrade to either a R9 270x or 280x and here is my question. Im not particulary bothered about selling my current 7770 to get the extra few pounds (yes im in the UK) to put towards the new card, while i am wondering if it would be any benefit to have them both in the system? would they 'argue' with eachother or would it be fine?
thanks in advance :)
FX-8320 | EVGA GTX 970 FTW | 16Gb Corsair Vengeance 1600Mhz | Corsair H100i | Corsair 500R case | 120Gb boot SSD + many HDDs | Gigabyte MB 970 Chipset | Razer Black Widow Ultimate 2013 | LgTech 420 | 3D Connexion Space mouse Pro <- love this!
Motorsport Engineering Student from the UK
https://linustechtips.com/topic/104578-2-better-than-1/
They would work independently. There shouldn't be conflicts but it wouldn't help unless you're driving multiple displays from both graphics cards.
https://linustechtips.com/topic/104578-2-better-than-1/#findComment-1398635
Yes, if you plan on having more displays then  you may use it. Otherwise don't bother with such things. Sell it and get the 280x.
  • CPU i5 3570k - 4.0 Ghz | Motherboard Intel DZ77SL50K | RAM Corsair Vengeance 4GB 1600 BUS DDR3 4GBx1 | GPU 2x Sparkle GTX 570 OC editionCase CM 370 EliteStorage Seagate 1TB 3.5" SATA HARD DRIVE 64MB CACHEPSU Cooler Master GX series 550W (80+ bronze)Display(s) Samsung 46' series 5 TV(1080p), Dell 20' (1280x1024)Cooling 3x Corsair SP120 QUIET EDITION HIGH STATIC PRESSURE 120MM FAN TWIN PACKKeyboard DELL original default keyboardMouse A4 Tech x2 800dpi | Sound On board~!
https://linustechtips.com/topic/104578-2-better-than-1/#findComment-1398646
IF you want to run them as one card, then they need to be identical cards and linked in Crossfire. Having two different cards won't really help you, so I don't see a reason to do so.
Case: Meatbag, humanoid - APU: Human Brain version 1.53 (stock clock) - Storage: 100TB SND (Squishy Neuron Drive) - PSU: a combined 500W of Mitochondrial cells - Optical Drives: 2 Oculi, with corrective lenses.
https://linustechtips.com/topic/104578-2-better-than-1/#findComment-1398647
They're not gonna work together. They won't "argue", but they won't "talk" to each other at all. So give the 7770 to someone else or sell it on craigslist
https://linustechtips.com/topic/104578-2-better-than-1/#findComment-1398651
You could use the 7770 to drive an extra display while you game on the first, Don't know whether it will increase performance though
  • Cooler Master Storm Enforcer
  • I7 3770K @ Stock
  • Gigabyte Z77X-UD5H
  • AMD Radeon R9 290
  • Cooler Master Hyper 212+
  • 16gb Corsair Vengeance 1600mhz
  • 2x 1tb WD Green Drives (RAID 1)
  • 256gb Samsung 840
  • Peripherals
  • Logitech G502 Proteus Core
  • Ducky Shine 3 - Blue LED, Brown Switches
  • Samsung SyncMaster 2443
  • Custom Mousepad http://imgur.com/xJWASQM
  • Logitech G35
  • Altec Lansing Octane 7
https://linustechtips.com/topic/104578-2-better-than-1/#findComment-1398657
Like others have said the only real benefit would be if you're running extra monitors, otherwise there would be no point in having it in your PC with the new GPU.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/104578-2-better-than-1/#findComment-1398713
thanks for the answers guys! i didnt think they would crossfire being two different models of cards. Im only going to run a single display so I shall see what i can get for the 7770 then.
Thanks again!
https://linustechtips.com/topic/104578-2-better-than-1/#findComment-1399431
