I dont know if its the RAM thats reducing FPS or what. I have 3/4 sticks occupying the DIMM, two of them are SK Hynix RAM of the same model 2x4GB and another is a random Samsung RAM which is also 4gb. I open CPU-z and it tells me that my RAM is being run in dual channel mode. Is that including the odd samsung stick?
https://linustechtips.com/topic/1045396-ram-help/
Does your mother board support quad channel memory? What motherboard do you have?
My Current Build: https://uk.pcpartpicker.com/list/36jXwh
CPU: AMD - Ryzen 5 3600X | CPU Cooler: Corsair H150i PRO XT | Motherboard: Asus - STRIX X370-F GAMING | RAM: G.SKILL Trident Z RGB 2x8Gb DDR4 @3000MHz | GPU: Gigabyte - GeForce RTX 2080 Ti 11 GB AORUS XTREME Video Card | Storage: Samsung - 860 EVO 250GB M.2-2280 - Sandisk SSD 240GB - Sandisk SSD 1TB - WD Blue 4TB| PSU: Corsair RM (2019) 850 W 80+ Gold Certified Fully Modular ATX Power Supply | Case: Corsair - Corsair Obsidian 500D RGB SE ATX Mid Tower Case | System Fans: Corsair - ML120 PRO RGB 47.3 CFM 120mm x 4 & Corsair - ML140 PRO RGB 55.4 CFM 140mm x 2 | Display: Samsung KS9000 |Keyboard: Logitech - G613 | Mouse: Logitech - G703 | Operating System: Windows 10 Pro
https://linustechtips.com/topic/1045396-ram-help/#findComment-12400909
45 minutes ago, tahmid133712 said:
Can someone give me a more detailed answer please. I don't know if I should keep the odd stick in there or not
You cant use 1 or 3 sticks. Use 2 only. Make sure they are in the correct slots for the motherboard and you will be fine.
https://linustechtips.com/topic/1045396-ram-help/#findComment-12401110
I see now, in more detail in CPU-Z, I am told that the 2x4 sticks are both running in dual channel and the odd stick is running in single channel. Will that affect performance?
https://linustechtips.com/topic/1045396-ram-help/#findComment-12401120
