Hello guys,
I got a simple/not so simple problem.
When I turn on XMP profile on my computer, it turns off fully and straight back on, booting into windows.
Problem I got is, everytime I turn my pc 100% off/cut its standby power by turning off my extension lead. It does this one power cycle everytime. Is this normal?
I got some G.Skill Trident Z rgb 3200 MHz, Asus maximus x code, And an i7 8700k.
Hope anyone got a tip or help, otherwise all works fine on my pc and rams. Just worried about this one power cycle it does everytime I cut the power.
https://linustechtips.com/topic/1045364-xmp-help-needed/
Yes this is normal, its memory training your ram on each boot. Mine does the same. You'll need to swap out your power extension. Some systems can power cycle multiple times, on some overclocks my system can power cycle 3 to 5 times trying to get a good timing to successfully boot in to windows.
My Current Build: https://uk.pcpartpicker.com/list/36jXwh
CPU: AMD - Ryzen 5 3600X | CPU Cooler: Corsair H150i PRO XT | Motherboard: Asus - STRIX X370-F GAMING | RAM: G.SKILL Trident Z RGB 2x8Gb DDR4 @3000MHz | GPU: Gigabyte - GeForce RTX 2080 Ti 11 GB AORUS XTREME Video Card | Storage: Samsung - 860 EVO 250GB M.2-2280 - Sandisk SSD 240GB - Sandisk SSD 1TB - WD Blue 4TB| PSU: Corsair RM (2019) 850 W 80+ Gold Certified Fully Modular ATX Power Supply | Case: Corsair - Corsair Obsidian 500D RGB SE ATX Mid Tower Case | System Fans: Corsair - ML120 PRO RGB 47.3 CFM 120mm x 4 & Corsair - ML140 PRO RGB 55.4 CFM 140mm x 2 | Display: Samsung KS9000 |Keyboard: Logitech - G613 | Mouse: Logitech - G703 | Operating System: Windows 10 Pro
https://linustechtips.com/topic/1045364-xmp-help-needed/#findComment-12400913
Thanks for your quick answer.
My extension lead is fine. When I leave the house I turn my whole electricity off as I'm scared of surges or etc. (Or what do you mean swapping extension lead?)
You are 100% sure that my pc got to power cycle every, I mean every single power on.
It does power on for like 1 second and then totally turns off and then restarts within 2 second.
I'm scared I did something wrong???
Thanks in advance ?
https://linustechtips.com/topic/1045364-xmp-help-needed/#findComment-12401097
Thanks in advance ?
It is completly normal, mine does it and I'm sure a whole bunch of people have it here. Like I said before it can even be more power cycles. You rely have nothing to worry about.
https://linustechtips.com/topic/1045364-xmp-help-needed/#findComment-12401114
