I have a 60hz Dell monitor and since I got my RX 570, I haven't seen any higher FPS than 60. I have removed all frame limits in RTSS and Radeon manager but no games go above 60fps. It's fine for me now since I'm on 60hz but is the GPU underperforming or is it outputting at lower frames to match 60hz? I also removed an odd stick of Samsung DDR3 4GB because it didn't match my 2 SK Hynix sticks although it was running in dual channel according to cpu-z, removing it somehow helped my FPS.
https://linustechtips.com/topic/1045276-fps-advice/
Vsync?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1045276-fps-advice/#findComment-12399911
2 hours ago, tahmid133712 said:
Vsync is turned on for all games. I'm a noob at pc gaming but is that the problem
yeah, you'll get a lot of tearing with it off though.
(◣_◢) Ryzen 5 3600,   Aorus X370 K7,   XPG 16GB 3200,   Gigabyte 2070 Windforce Corsair RM650x,   LG 32GK650F-B 31.5" 144Hz QHD FreeSync VA,   Kingston 120GB SSD,   Samsung 1TB 860 QVO,   2TB HDD,   Fractal Design Meshify C,   Corsair K63 Wireless,   Corsair Gaming M65 PRO,   Audio Technica ATH M50x,   Windows 10 ProCorsair H100x 240mm.  (◣_◢)
(◣_◢) Ryzen 5 1600,   Noctua NH-L12S,   Gigabyte GTX 1060 6G,   ASUS Prime B350 Plus,   HyperX Fury 8GB DDR4 (2666MHz - 1.3v),   SilverStone ET550-B,   Kingston 120GB SSD 2TB HDD,   Cougar MX330,   Windows 10 Pro.  (◣_◢)
https://linustechtips.com/topic/1045276-fps-advice/#findComment-12400143
Vsync limits framerate, yes.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1045276-fps-advice/#findComment-12400740
